Layout Designing Software
I’m sure this has been asked many times, but I’m going to do it anyway:
What is the best designing software for a first timer? I’ve tried the free software from Atlas, but that one dosen’t give you a choice of number 4, 6 or 8 turnouts, it only uses right and left snap switches. I want to find something that is compatable with HO and N scale.
Any info will help, Thanks
In the Atlas program, go to ‘Elements’, and ‘load library’. The HO code 83 library has 4, 6, & 8 turnouts. However, if you want to get a turntable, you will have to go to the HO code 100 library and use that one, but it will work with the 83 stuff on the drawing.
[#ditto] On the Atlas elements.
Here’s a program that’s real EZ to use. Not much learning curve. They have a free trial version and it’s well worth the money.
http://www.anyrail.com/index_en.html
I use, and like, Xtrkcad. http://www.xtrkcad.org
Some swear by it, and some swear at it. It is free. It has a bit of a learning curve. I alsways recommend doing the demo/tutorial, then working with it a few hours, and then repeating the tutorial. Lots of things make a lot more sense the second time around.
In my mind it does everything I need. It will not do a 3-D rendering, but it does keep track of elevations and grades. It also allows you to create any elements that may not exist in the libraries. There are additional libraries available in a Yahoo! group.
I use 3rd PlanIt and really like it. http://www.trackplanning.com/ It does pretty much everything and you can place a train on your virtual layout and watch it go around the track.
What’s the name of that Yahoo group? I’m looking for some additional rolling stock elements for XTrk
Thanks!
Cleverly enough, XtrkCad!
http://groups.yahoo.com/group/XTrkCad/
I found it. Great, and thanks again!
[yeah] Ditto to all Jeff said. XtrxCad is the way to go. One thing he didn’t mention is that you can create a 1:1 (actual size) print-out of your perfect dessign, use carbon paper to trace it onto your layout and you wind up with a flawless, derailement-free, perfect layout. Spend the time to learn it.
I gave up on LDS. The earning curve is too long, and LDS doesn’t have all the capabilities I want. I returned to paper, pencil, protractor, compass, and erasure. Then I proceed with full-scale templates (like FastTracks) in the critical areas to see how things fit. Seeing how everything really fits (or doesn’t) is a revelation.
Mark
