I wish someone would write a book discussing track plan elements rather than complete track plans. What I mean by element is just the siding(s) by a coal mine, station, terminal, other industries. I know you can look for these elements in the track plans, but I think it would be more helpful to have a book focused on interesting elements and discussing what makes them, or how to make them interesting. This would include track work, as well as scenic details.
I don’t know how many people actually build a layout from a track plan book, but I think many more people could incorporate the ideas in track elements into their layouts.
Another great source of inspiration I have found is to pick an area you are interested in, then see if they have a historical society nearby. Often there are town plats showing local rail service installations, i.e.: track arrangements serving particular local industries. Quite often you will also be able to get copies of old photos of the actual buildings. Enjoy the learning curve! John
These sort of already exist. They are called Switching Modules. You can use them to start a layout or build them as modules to include in a larger layout.
My last two layout started by using Switching Module plans, and one used three Module plans as towns.
The good thing about using module plans is that someone else has designed the track plan, and they usually work very well. For individual industries along the line, just add a passing track with a siding or two off of it. Very simple.
If you have access to back issues, many articles on modeling full size railroads in MR and RMC have broken the larger runs into smaller elements, and included suggestions for linking them. One that comes to mind, was MR’s “Building a Wabash Branch Line”. They started with the interchange from mainline to branch, added a small passing siding with one or two small sidins, and then had a suggestion for the end point at Columbia, Mo.
Thanks for the book suggestions. I’ve read about the Koester book but haven’t seen it. I have an early edition of Track Planning for Realistic Operation*,* which I’ve read several time. I also found and ordered a used copy of Creative Layout Design.
But with so many track plan books and articles, I guess there isn’t that much interested in track elements. I realize that integrating elements into a complete layout is also an art.
As an example, the wye at the end of “Dual-gauge HO Track Plan” in the jan 2010 MR is a track element that I think could be shorter article in itself. Such an article could discuss scenic issues, as well as how it might be integrated into different types of layouts, both big and smaller.
Hmmm. First you bemoan the fact that no one has written any books about “track elements”.
When informed that there are actually several such books on the subject easily available, you comment “I guess there isn’t that much interested [sic] in track elements”.
Just curious - how did you arrive at that conclusion ?
A couple of good magazines for track planning of scenes is the LDJ (Layout Design Journal - the membership magazine of the LDSIG - Layout Design Special Interest Group) and MRP (Model Railroad Planning) - an annual from our hosts here at Kalmbach.
I rather dislike the idea of a book of “track elements” or “design elements”. I think it encourages cafeteria style layout design. That is, someone designs a layout by saying I need a coal mine, a turntable a yard and a team track, selects them from a list of plans and strings them together. I prefer picking an operation or an area, then designing the track to fit the operation or resemble the area
But with the Duplo, Lego, RTR approaches to modern modeling, books of track elements probably will be an idea that comes, whether or not its a good idea.
Seems to me incorporaing published design elements into a layout is exactly what the modular crowd does. Some seem to design their own, while others incorporate modifications to published design elements.
Wouldn’t somebody building a published layout just be building a large Duplo-Lego design eleoment? Even putting in a simple double ended runaround with a siding, even if designed in place, is simply repeating a previously publish and multply duplicated design element. So is running a team track from the mainline.
A published book of design elements may provide some people with a source of “cafeteria” layout ideas, but for another group, me included, would provide a guide to designing a situation on my future pike. Not copying, exactly, but a simple design to customize to fit my space. Like I did with the Columbia, Mo branchline article I believe I mentioned earlier. It culd have been built as laid out in the article, I believe something like a 3.5’ X 5.5’ module. Instead, I used a set of calipers and a ruler to enlarge it to a size approximation of the full size location, with the capability of duplicating the mixed train pictured. That gave me the terminal spure capable of a Geep, about 5 40’ cars, and a 62’ clerestory combine, with room to spare. That gave me a table about 6.5’ X 12’. One design element, If I were to do it again, It’d be closer to the size in the article.
Let’s face it, a large part of this hobby is copying (modeling) operational situations, which could be considered design elements: portions of a whole.
Not sure I understand where you’re going with that… I think the “cafeteria” style approach to layout design is actually pretty prototypical. That being said, you’re not likely to find a coal mine on a Florida East Coast layout, nor would you need a car float in Kansas… But in terms of a modeler building his railroad to suit his interests, then what’s wrong with pulling from a menu?
I believe the LDE approach is pretty groundbreaking. It has helped the concept of a shelf layout to really evolve, and helps everyone from roundy round railfans to hard-core operators to design and build better looking layouts. It encourages us to look toward the prototype for inspiration, and also helps bring our sometimes scattered ideas into focus. An LDE can be either a purely scenic element, such as a particular bridge or a grade crossing, or it can contribute to the layout’s operation, like a town or a passing siding.
And in the end, it’s really just an extension of Armstrong’s immortal “Givens and Druthers” with an emphasis on the latter.
Speaking of Jack Armstrong, one could consider his discussion of planning for realistic operation an example of layout elements. I actually created a number of small designs using that book and from an Atlas planning book while brushing up on my RightTrack skills. Some of the design elements (such as curved staging, yards and passing sidings have made it into the design I am working on. I have published a few of the RTS files on my web site.
Its actually the LDE (or the misunderstanding of the LDE) that led to my comments. Much like the “domino”, it is a concept that has morphed into something quite different than what it started as. The original concept of the LDE was that you would identify design elements, signature locations, track arrangements or scenery that would define your chosen prototype. By replicating an LDE you would capture the sessence of the prototype and more successfully replicate it. So with the original LDE concept, 10 people could model the same prototype and each could have different LDE’s depending on what they saw as significant to their layout.
By just picking random scenes or elements from a menu of scenes or elements the modeler is actually doing almost exactly the opposite of what the original intent of the LDE was. Rather than identifying the critical elements of a specific scene, the picking scenes out of a book would be creating a generic scene. By using a book of LDE’s it separates the element from what inspired it.
I see it as the difference between an author writing a book by first choosing a plot and outlining the key plot twists and an author who chooses sentences or paragraphs that others have written and assembles them into a story. Maybe I’m looking at layout design from too artistic a perspective.
How is this any better or worse than getting a book of 101 track plans? You know, for sectional track on a 4x8 where the trains go 'roundy round-- yee haw. Its the same thing just taken to the next level. Or else its for people who want to get started in the hobby who don’t have the same skill or knowledge level as others-- or perhaps that’s just all the time they have to dedicate to it-- the rest of their time being taken up with making peace in the middle east and finding the cure for cancer.
For me personally, I think anything that helps someone get started in our hobby, or a leg up so they can get past difficult stuff, is good for our hobby. It helps spread interest and enjoyment to newcomers. It helps the publishers and manufacturers sell books and “train stuff” and stay in business. And it helps people “achieve” something more quickly and perhaps better maintain their interest in this instant-gratification everything-wrapped-up-in-an-hour world of ours.
And if nothing else, maybe it helps people learn about stuff, find pointers to information, learn terminology and lingo, and find out about concepts and operations in an easy-to-obtain, readily-available source. That’s why I buy 'em. They give me ideas.
Yes, different people might pick different scenes to model, and different people might even pick different aspects of the same scene to model.
Yes. And that is not a big problem, unless you feel that a scene or scenic element on a model railroad must be a representation of a specific prototype scene from a specific prototype railroad.
If you are indeed looking for generic inspiration, then it is not a problem that the LDE you are looking at is from a different place. You may not be modeling the exact same town or same junction, but you could be looking for inspiration for a freelanced or protolanced similar type of town or junction.
It could still prove interesting to see which which aspects of a similar scenes someone else has judged to be the essential parts(s) of their scene on their layout.
Maybe not. If you are looking at a whole layout, then you are seeing the whole design. You can see how the parts fit together. With an LDE you are looking at just one part (unless you are defining an LDE as an entire facility or very large area) and so don’t necessarily see how it fits in to the rest of the operation.
Not necessarily. A railroad is part of a network. The pieces are designed to work with each other. Regardless of whether you are freelancing or modeling a prototype, if the parts don’t work together then it won’t operate well. If you know enough to blend the parts, you probably know enough where you really don’t need the LDE’s.
Certainly. Of course, it really depends on the person looking at the track plan. Some people can figure out likely operations by looking at a track plan, some can’t, no matter if they look at the track plan for the whole layout or the track plan for just an LDE.
Mmm. I obviously agree with you that a railroad is a part of a network, and that if parts doesn’t work together then the layout won’t work well as a whole.
But consider this: you (and I) can look at a whole track plan and see how the parts fit together as a whole, and figure out how operations on that layout likely is run just from looking at the track plan. And either of us can also look at an LDE and figure out how to fit it into a larger plan.
But someone who has not read much on track planning or track analysis but still want to design their own track plan will have trouble figuring out even fairly basic things by looking at either a whole track plan or an LDE.
And while one certainly can hope that the whole track plan they are looking at will have been designed in such a way that it works as a whole, the fact remains that most track plans published tend to end
One of the things that I dislike about track planning books, of either ilk, is that they say things like: look at google maps or sanborn maps to see how real railroads did such and such and then use those for templates. Nevermind the fact that if I didn’t know what I was looking at before or what/how it operated, I’m going to be only slightly more informed afterwards. And then invariably in the next breath they’ll remind you how “difficult” it is sometimes to discern the proper operation of “real” railroad track plans because they might place a critical runaround track (or some such) in the next town over that won’t be obvious to the casual observer. Okay. So, like, how the heck am I supposed to learn anything with that prosaic humdinger?
Also, fwiw, I’ve got the trackplanning books by Armstrong, and the books with the myriad 4x8 loopty-loops and probably every Kalmbach book ever made (Back atcha there Al) I’ve studied the plans published in every issue of MR and RMC I own (which is most of them, going back to the early 40’s), read all the advice, listened to all the pundits, read up until I’m blue in the face about “plausibility” and two years later I’m still no closer to an actual track plan than I was when I started.
I do have some “scenes” in mind that I really want to model though, for starters. And I know my location, era, road, “back-story history”, etc., and I know my givens & druthers, I have mapped my available space down to the millimeter in all three dimensions, and I’m now on my fifth (and I think my final) benchwork revision. Photos to follow soon.
I know-- I’m just kvetching. It’ll come, I have faith.
