Hello to everyone!
I know I’m not the only one who asked for help here regarding his layout design, but since this is my first layout, I’m all about learning and getting tips and suggestions from you guys.
My layout won’t be big by any mean, and is unfortunately against 2 walls. I’ve already built the benchwork, but that’s about it. As you can see on the plan, the base benchwork measure 9’x4’, with a 4’x1’ L-shaped extention at one end. The walls are at the top and to the left. It’s deeper than what most people recommend for easy access, but I wanna have a run-around layout, and this was the best way I could find to utilise as much space available as I could.
I’m gonna build everything in HO, as I already have some rolling stock and structures, but I would like to use flex track (Atlas Code 83 or something similar). Right now I have a bunch of Bachmann steel EZ-Track, but it’s only temporary. I’ll go the DCC way, as it seems to be the most practical and future-proof way.
I’ve been looking at a couple track plans that gave me some ideas. A couple of them had 8-figure mains, and without having something that looks toyish, I tried to integrate an overpass in my design. that way, it gives me a longer run. On the other way, I’m looking for a minimum 2.5% incline with this setup, and it adds to the complexity of the plan. I don’t wanna go under 18" radius curves, and I tried to integrate as many 22" turns on the main as possible. Since I wanna go flex track, I’ll try my luck with progressive (spiral?) curves.
I’m not looking to run very long trains, something like 1-2 GPs and 10-12 cars maximum. I’m setting the timeframe around 1970-1975, so maximum car lenght should be around 60 scale feet (hoppers, box cars, gondolas, tank cars, centerbeams). If possible, I’d like to run a 3-cars Pullmans but I realize curves may be too tight.
I’ll add some industries along the main: a grain elevator, a freight house, maybe a scrap yard, lumber or some sort of gravel pit/min
