Layout Lighting for a new layout space in the basement - suggestions wanted (pictures on page 3)
Here’s my situation: I can free up a quadrant of my basement for model railroading purposes. I’m good at electrical work, so I can install any circuits and lighting that I need. But I’m not sure what all my options are.
For lighting shelving and other storage, I’m thinking either fluorescent strips or track lighting (to direct into the space). Work areas, like a bench or crew space, will have fluorescent strips or maybe some train-themed lighting (any suggestions?).
But for lighting the layout itself, I’m not sure. Here’s how my thoughts have gone:
First, track lighting. But a lot of track lighting is halogen – it gets hot, but the basement almost never gets hot (I’m in Minnesota). UV is a bigger worry, but you can get filters to address that.
Next, fluorescent, even compact fluorescent in shrouded fixtures. Low heat, long life, but not sharp, and there’s some color variation at times. Also can’t be dimmed unless you get special ballasts.
I have this dream, though…
Lighting for the layout that could be linked to a fast clock for the purpose of mimcking the change from daylight to ‘night’ light. Does such a beast exist? I can see night being a flavor of blue light, but the true dream system would have warmer tones for sunrise and sunset.
I could always install generic fluorescent strips for general lighting during construction and such, but for operation, something more dramatic would be desirable. And I’m spoiled in that, since I do community theatre, and now how to do theatrical lighting design and operation.
Jacob
[#welcome] Sounds like you may be a pioneer in the fast clock linked to lighting idea. I guess you are stuck with incandescent for that. Flourescent also has different color values than incandescent, as you are aware. What that may mean for modelling is that your paint booth light should be the same type as your layout light.
Halogen I’ve no experience with on a layout. Heat is a factor if cooling air isn’t good. Do you like the “harshness” of halogen? Think of the shaddows thrown by the models, and where they may fall.
The generally received wisdom(GRW) is to install your ceiling and lighting before the layout benchwork, so your idea of having flourescent to work by and later some other system for operations may need a little logistical forethought. But then, GRW says to put up your backdrop before the track and scenery, and how many of us get around to being that smart? [banghead]
Basement layouts(and layouts generally)need quite a bit more light than is ordinarilly realized. You know all this from the theatre.
My [2c] would be to go for incandescent , and also provide for special areas and scenes within the overall lighting plan.
Good luck on the fast clock thing. Don’t forget to make notes and photos so you can write it up for magaizne articles.[8D]
For general lighitng I would go with the fluorescents. There are a wide variety of lamps available that will allow you to get a good look to your layout. I would use the same lighting at your work bench so that you don’t different colors out of items under different types of light. Things look have different tones under fluorecents vs incandescents. But for the ability to go from day to night you will need incandescent lights. It can be done with fluorescents but it would be expensive.
John
I use florecent lights but I did put in recessed lighting for time of day scenerios…I installed 12 recessed lights, 4 bulbs are blue for night time, …four bulbs are yellow from morning and evening lighting, and four bulbs are white for daytime lighting…I use the florecent when i work on the railroad but use the other lights when i’m operating…Chuck[:D]
I’m not too worried about backdrops and benchwork, since I’m thinking of modules at the moment. Different scenes, like dioramas, but when connected the proper way give you operational capability.
One idea I had was to build the lighting into the module. You have to design the module to be viewed from one direction. Then you make a cyclorama that curves up the back, like half of a parabolic curve, with the focus being above the module.
The back of the module is for the skylight source. This is where your blue sky, red sunset, what have you, comes from. So there’s a gap between the back of the module and the cyclorama’s base that admits your light source.
The top of cyclorama has a valanced area where your spotlights are. These are what mimic the sunlight.
Assume you have red-green-blue color source for the cyclorama lights…maybe add white for reducing saturation, then you just need to figure out the curves for brightness of each color channel at each point in time on the clock, fast or otherwise.
The spot lights would also have a curve to match the level of sunlight.
Deluxe is to have the model lights for buildings and streets operate like this, too. The streetlights are almost an inversion of the curve for spot lights. But building lights are nearly random, but taper off late at night.
Anyway, each module could be on a fast clock bus, so you could use a controller for the lights on each module. The controller would let you set a gross season - summer, fall, winter, spring, to determine if the day/night was balanced or biased towards one extreme or the other. Short winter days, long winter nights.
And the icing on the cake would be some sort of fibre optic star pattern for night, but maybe it could be faked by some spotlights with patterns (gobos) on them…such an instrument would probably be too involved for the area. I always imagined the spotlights to be low-voltage halogen for the brightness and dimming c
Jacob, My son and I are building " another " new layout and we want " stage " lighting
also. We are going to use the new rope lights hooked up with dimmers. You need white and red and blue to make morning, daytime and night effects. We have done this before with colored lite bulbs but you get brite spots and dim spots. The rope lights spread the light
out much more evenly and you can easily add more light with more ropes. We are going to put aluminum foil behind the ropes to increase the light downward and as a heat shield for the valance. I have never heard of a way to adjust the dimmers except by hand. This would be a subject that our electronic friends might want to to work on.
Ray
rayhippard:
How about giving us a little info on “rope lights”. I have never heard of them.
thanks
Richard
Rope lights are similar to christmas lights. They’re a string of small lights in a colored or clear plastic tube for decorative lighting. Most Home Depots or Lowe’s have them in their lighting department.
Since you are into theatre, do it exactly that way.
Two sources on every area with differing whites from the front. Some soft should be supplied from the back or above.
Some architechtural dimmers will allow simple contacts to trigger changes, I believe I saw a fastclock with external outputs for sound systems, perhaps they can be used in conjunction with a relay to trigger the dimmer inputs.
This won’t be cheap, but you will have some bitchin lighting.
I’m trying to figure out a solution that will reduce the amount of invention I need. grins
One thing I found, though it is measured in hundreds of English pounds as a cost, is a scene dimmer with multiple channels. It can be programmed with events, and probably cross-fade from scene to scene.
For the non-theatre-techies, let me explain:
Let’s assume that you want to light your layout throughout the course of a simulated day. So you need full daylight, full night, and a dusk/dawn. These would probably be represented by white lights, blue lights, and yellow (or amber or red) lights, respectively. Let’s expand it a bit, and say that dusk is more red, and dawn is more yellow.
The result is four channels: white, blue, red, and yellow. In reality, each channel would be a light source – rope lights, strip lights, incandescent bulbs, what have you. The catch is that the sources must be dimmable. (Fluorescents generally aren’t, though some compact fluorescents are designed expressly for dimming.)
A scene dimmer that can control four channels means that it can have a different light level for each channel. Let’s suppose our scene dimmer can hold at least four different scenes. We might lay the scenes out like this:
Sc. 1, Dawn: Red channel at 25%, Yellow channel at 75%, White channel at 0%, Blue channel at 0%
Sc. 2, Daylight: Red channel at 0%, Yellow channel at 0%, White channel at 100%, Blue channel at 25%
Sc. 3, Dusk: Red channel at 100%, Yellow channel at 25%, White channel at 25%, Blue channel at 0%
Sc. 4, Night: Red channel at 0%, Yellow channel at 0%, White channel at 25%, Blue channel at 75%
We can program the scene dimmer with these values, and then we only need to select that scene on the scene dimmer in order to have our lights at the levels we programmed.
But wait, there’s more!
It looks like multi-channel scene dimmers can have some timing and pro
Things are looking up!
As I mentioned in the last post, the device to get is a scene dimmer, residential grade. There seem to be two big companies that do something like this.
First, there’s Futronix. Their web site is http://www.futronix.info/ --I got messed up when I found it via Google, and ended up at the UK site. Since then I learned that the P800 system, which has eight channels at 600W each max, and a total dimmer load of 1000W, costs only about $542.13. They have manuals on-site to explain pre-installation considerations, and how to install and program the dimmer.
Then there’s Leviton. They make several lines of products, but it appears their big scene-based stuff uses X10 technology. This involves sending a signal on the AC power system itself. It’s main use is whole-house control; without adding any additional wires, you can set up a house control system for your lights. The thing I’m not clear on is whether or not you can program sequences into this system.
That’s the goal. I’m working on the assumption that I can have an operating session that runs two or three hours, so I’d want the ability to program in a lighting cycle to mimc the lighting conditions within that window. It wouldn’t be connected to a fast clock, but that’s OK. What worries me is that the Leviton system looks like it could only do this if you got a computer running Visual BASIC hooked up to the system, and that would cost more than the Futronix system that does it already.
I think if you had the basement empire, and wanted to spend the money, you could get the architectural/commercial grade of Futronix scene systems and be all set. But it uses three types of power inputs, and needs a closet to hold the dimming equipment. This would come as no surprise to anyone who has worked in a theatre, but I suspect most homeowners think of a dimmer switch as a simple dial – a variable resistor – but there’s more to even those simple systems, and bigger ones need a lot more.
I just finished adding lighting to my lay out. I used the undercabinet low voltage halogen lights, like the ones you find under kitchen cabinets. I spaced them two feet apart and placed them 3 feet above my lay out. So far I am very pleased with the look. They give full coverage of my lay out and they are dimmable. They are 12v 20w bulbs and give off a crisp natural white light and some heat, but my lay out is in my basement which is cool any how. The lights are designed for bookshelves and displays. I also have fluorescent lights for general room lighting.
What a low price! I was expecting a $2000 minimum. Looks like an excellent system! I think a company called Smart Home sells all sorts of X-10 accessories for timer control.
I’ve been thinking about using these to light the lower level of my soon to be built layout. My wife has used them for a couple of projects (built in bookshelfs and to light the kitchen counters) so I have an “expert” at home for advice on installation. I haven’t decided on the overall lighting yet, so I am reading this thread carefully.
jhugart,
I use fluorescent lighting for general work sessions and have track lighting with halogen 75w bulbs for my operating sessions. The track lighting is great to add focus to specific areas and you have the versitility to adjust them as you want., change wattage, control them, or later change to color bulbs.
Try your local electrical supply house for light controllers. They should be able to suggest a unit that will match your needs.
Another device that will do all the things you are talking about is called a Programmable Controller. They cost from a couple hundred dollars to thousands. Industry uses them to control processes and your city to control your traffic lights. They contain internal relays, timers, counters, discrete input/outputs(on/off), analog input/outputs (varying voltages) and many more programmable instructions. Some are programmed with a simple built-in keypad and higher levels will use an interface with a PC. You program them to operate within the perimeters you set. i.e. If you want a light to turn on in 1 hour and another to dim to 50% after you throw a switch twice and everything to turn off after 4 hours—just program it. Maybe high end for what you want , but I’m sure your electrical supply house can fix you up.
Just thought of something that would work and not cost much nor be complicated.
Go to http://www.x10.com
They have remote control dimmers and on/off switches and etc…for your home. They also have a computer software program (runs in the background) that with an inexpensive interface will control lights by time with these remote modules to turn on/off or percentage of brightness.
REX
No, my local store doesn’t carry theatre grade dimmers.
Smart Home sells all sorts of x10 accessories. If you had read the replies, you would have seen x10 disscused.
[/quote]
Ouch! [B)]
Sorry, but there was an unanswered question mentioned, “… a way to have programmed control with X10”.
You only need the computer that you are posting on right now. You connect the interface to a serial port and a wall plug–thats it.
The programming is very simple. Just select on a screen what you want and set times and dates.
X10 software will control an entire house with your PC by your programming. It will turn lights on or dim them to what ever per cent when you want and anytime you want it. It is based on real clock time. You can have a light come on at 7pm and dim to 50% at 7:10 pm. then to 10% at 7:20pm and turn the coffee pot on at 8am on Saturday, Aug 30. It will control as many modules as you have installed. You probably can do what jhugart wants for $300 to $400 including modules.
I have used this and their cameras for my house security for two years now and am very pleased with it.
[quote]
It looks
Rexhea, do you have track lighting on the ceiling above the whole layout ??? I have been toying with this idea as well. I work at Home Depot in the electrical/lighting department and have first hand knowledge of most of the products that are being discussed. I also like the idea for the under the counter halogens, but my layout right now is just one level with out anything on top. right now its just clear to the ceiling.
josh
I plan to visit some local lighting specialty stores to see what they think. The controls are the part that will let me do the fun stuff.
X10 looks interesting, but I don’t want to use a computer to control all this stuff. The one I’m using right at this moment is owned by my employer, and I don’t think they’d approve of me taking it home for use as a glorified light switch. grins
Since I’m in a basement scenario, and not going to a multi-level plan, I’d use track-lighting on the ceiling. The trick would be getting enough lighting without blowing the controller. Let’s assume that one 50W halogen bulb can illuminate 2’x4’ of layout space. With a limit of 300W per channel, that’s only six lamps, quite a limitation. And the scene dimmers have total wattage limits that may be less than the total of the limits of each channel added up.
Big Boy’s suggestion sounds great, but if it was at the MoA, then it was surely commercial grade. I’d be willing to believe I could accomplish anything with that grade of product.
I’m sure there’s a way to get the effect, when I get a solution, I’ll post.
