All of my locomotives are starting and stopping all of a sudden. Then I caught this loco doing this with it’s lights. Do I have a short somewhere? Is my NCE SB5 starting to fail? The track was cleaned as were the locos so I have no clue what’s going on. Hoping what this loco is doing with it’s lights can give me some insight.
Were you adjusting the speed of the loco when that was happening? It looks like the loco is set for 14 speed steps and the command station is sending 28 speed step commands. In 14 speed step commands, the speed, direction, and headlight are all sent in one byte. In 28 speed step commands, the bit for the headlight on/off is used for the lowest bit of the speed command (the headlight is sent in a seperate command). The result of that is if the decoder is expecting 14 speed step commands and the command station is sending 28 speed step commands, the decoder sees increasing or decreasing speed commands as turning the headlight on and off as you go through the speed steps.
If all locos lose power identically, its not the cleaning, its the wiring and/or your power supply. Check for consistency and continuity before putting the locos onto it.
In the video that particular engine seems to be running fine but with it’s headlight flashing on and off. Is it possible that somehow or another the CV controlling that light got changed to some type of strobe or other flashing setting? If you know it’s an NCE decoder is in it, you can look up the appropriate CV and then read that CV from the engine and see what it is set to (or read all the settings in decoder pro, including the 14 vs 28/128 one) and change it so the light doesn’t go on and off.
