In the other thread a few guys mentioned Le Massena’s famous article in June 1968 Trains that tried to rank the largest US steam locomotives, both by power and by merit. As he commented on the engines’ merits he naturally included comments on the railroads operating those engines-- railroad A did a fine job, railroad B clearly was run by pointy-haired bosses.
He calculated the “potential power” of each engine in arbitrary units: square feet of grate area times pounds per square inch of boiler pressure. A UP 4-8+8-4 had 150 square feet of grate and 300 psi, so its potential power was 45000, putting it in second place behind the NP 2-8+8-4, which (initially?) had 182 sq ft and 250 psi.
Third place was one of those D&H experimental compound 2-8-0 from circa 1930, which had 82 sq ft and 500 psi. This raises a question, namely: Huh?
Fortunately he explained.
“Why select boiler pressure and grate area as measures of potential power? The reason is not difficult to comprehend. Going back to the high-school physics class…”
Mark that. It’s simple, he says-- no higher education required. In a couple sentences he’s going to make a clanger of a mistake, which the reader will be baffled by: could he really have meant that? I must be misunderstanding him-- it must be more complicated. But it isn’t.
“…recall that power is defined as how much energy is released or developed in a specified time. For steam, this energy is expressed as volume multiplied by pressure. Hence, steam “power” is boiler pressure multiplied by the quantity produced per hour or minute.”
I’m not sure that’s quite right, but close enough for us: power is pressure times volume of steam produced per unit time.
"Now, since the quantity of steam is related closely to how much fuel is burned per square foot of grate area, the fuel aspect can be eliminated by saying that for equal fuel consumptions [per square foot of grate], the larger grate area
