This may seem trivial to you all, but I have to share it.
As I have stated before on this forum, I moved homes last fall, so that meant disassembling my layout and reassembling it in my new digs. Alas, I have finally gotten to the point of getting it operational again, but not without some glitches; most notably with indicator lights. I run on DC, with toggle switches at each block, (ten in all), that select either of the two throttles. The toggles are the on-off-on, double pole-double throw type with solder tabs. The other pole on these switches is connected to LED indicator lights that light up when that respective throttle is operational.
With just a few “corrections” the track power all was up and running after it was all reconnected. It was the light power to my No. 2 block that baffled me; it was not operational at all. I tried everything to test it out to try to find the problem, including resoldering all the connections and replacing the 150 ohm resistor. To add to the peril while using a wire with aligator clips to go directly from the terminal to the light, I unwittingly connected the power, without a resistor, to the ‘A’ position LED and, naturally, I fried it, so I had to replace it too. To avoid this happening again, I soldered a resistor into the aligator clip testing wire.
So, in using this test wire method, I accidentally touched one of the other terminals. Voila! Lights! Each terminal has two screws: the top one to connect the jumper wire within the terminal strip, the bottom one to use for connecting to the LED. I tried yet another terminal position, then another and yet another and they all worked. The question was: what is the matter with the No. 2 terminal position? Well, I looked closer at it and the top jumper connection screw looked a little loose…
It required about a half of a turn to tighten it!
Lights at No. 2 block! Miracle!
Have you ever done such a dumb thing? This has to be at t
