Lets talk about wiring
Let’s talk about wiring. I figure I’m going to have a lot of questions. So let’s start with the little I know about it. Feel free to correct me here.
  1. If you are drawing a lot of amps you have to have heavier guage wire. Power tools such as worm-drive saws (draw 13-15 amps depending on manufacturer) need at least 12 guage wire to run 100 feet on a power cord or they suffer from voltage drop and can burn up. They use twisted wire.
  2. The same principle applies to house wiring. If you are on a 20 amp breaker you need 10 guage wire. On a 15 amp breaker you use 12 guage wire. Both of these are solid core wire.
  3. Data–phones and computer–is trasmitted over some pretty great distances using thin 24 guage solid core wire. For some reason, they twist it. That it is except LocoNet wiring which is a flat ribbon.
  4. The smaller the wire, the easier it is to solder to the track and make it look good.
  5. Soldering thin wire directly to a solid 12 guage bus isn’t as easy as it should be.
I want to understand the why of things so I can make decisions about my layout. For instance I have a sufficient length of 12 guage romex residential wire, and a lot of Cat 5–like half a box (250 ft or so 8 strand twisted pairs). I also have some short pieces of 16 or 18 guage solid core wire in red and green–probably enough to do the feeders.
First 2 questions:
  1. What is the advantages or disadvantages of solid wires vs twisted wires?
  2. Why are wires transmitting data twisted? I know they suggest twisting bus wires on DCC layouts, but from what I seen in reality on YouTube, the twisting is half-assed (and mostly, I think) to say they did it.
110 volt AC
15 amps = #14 wire
20 amps = #12 wire
30 amps = #10 wire
The breaker size is determined by the wire size. If the wire is smaller than the breaker size then the wire will burn before the breaker trips.
Amps times volts = watts
15 amps X 110 volts = 1650 watts
The power from your transformer is DC for starters and it is not 110 volts. It is usually around 12 volts. Therefor you don’t need #12 wire.
Twisted pair wiring came from the telephone company so that in a bundle of dozens of wires the pair of wires for each individual phone line stayed together and didn’t get lost in the crowd.
It’s not a matter of need but a matter of got. Is there a disavantage in going with too big a wire?
Bigger wire is stiffer and harder to work with. Also it costs more.
Thanks. Thing is, I already have the wire so there is no cost.
So if my bus is 45 ft long, what guage wire would you suggest?
I get the solid wire, but by “twisted”, do you mean, do you mean stranded wire, or runs of solid wire twisted together?
My L shaped dog bone continuous run is 50’, I used 14 ga. solid wire, red and black, for the main bus, and for the feeders, I used 22 ga. solid wire. I did twist the red and black bus wire together, just make it a little more confined, and then seperated them were I soldered the feeders.
I would think that the 12 ga. solid wire, the house wiring, would be fine for the bus. I’m thinking the 16 or 18 ga., might be a little big for the feeders, but I don’t know what your plan is for attaching the feeders to the track.
That’s why I used the 22 ga. Just a smaller wire to deal with, and hide, as I soldered mine to the outside of the rail.
As far as stranded wire vs. solid, the stranded is more flexible. I think the solid wire is better for bus and feeders.
Mike.
The biggest advantage of stranded wire it that it is more flexible and easy to work with.
Secondary advantage: it will still work just fine if a few of the conductor strands break. It you use solid wire, and it breaks, you are done.
This is so one conductor does not induce a current into the other one that is run parallel. Not a big deal in 12 volt track wiring, but with DCC this becomes a concern. The little “1s” and “0s” that make up the data packets can become corrupted. If the data pack is unreadable the intended receiver will ignore it.
All this time I thought twisted-pair coupling cut down on crosstalk between the pairs. Twisted-pair becomes essential in high-data-rate applications like Ethernet cabling.
If you are feeding relatively unmodulated DC down a ‘legacy’ length of twisted-pair, the value of the twisted-pairing probably defaults to what he said, useful color coding to pick out the circuit at the other end. If you are feeding even relatively slowly modulated intelligence over the DC, maintaining the twist right up to any connectors will still have value.
My last layout didn’t have a buss,Feeders { reclaimed 24ga} were droped down and pigtailed , a jumper went to another pigtail,and so on. Never a problem.
I wanted to clean it up,ran a 12ga buss,cause I had some on hand. 12ga is a bear to work with. On the new layout I decided to spend the money on 14ga bus,way better, and reused the reclaimed 24ga feeders. Thats on just over 50ft of track not counting the yard and sidings.
Somtimes you got to justify not spending money agaist stress
SpaceMouse,
Twisted data cables (like CAT/5) are twisted in pairs for self-shielding properties. They can resist outside interference better if they twist the matched pairs together.
LocoNet, however, is flat data cable. I’ve talked with Digitrax about this, and they recommend not using twisted pairs for LocoNet cables. Why? I dunno, but they know their system better than I do.
One good thing about bigger wire for DCC bus use is that you have less voltage drop and a therefore a better, clearer digital signal.
I believe 14g wire would be sufficient for a 45’ bus but since you already have 12g go ahead and use it, recognizing that it will be a bit harder to work with due to its stiffness.
I would ditch the 16g & 18g wire for feeders. I think you will be mutch happier with 22g solid. Easier to solder to the rails and to the bus. Plus the rail connection will look mutch better.
A 50 foot run from the booster to the end of track is a pretty long run. My longest track power bus runs are about 40 feet and I used 10ga THHN stranded for them. I used 12ga stranded for the shorter ‘occupancy zone’ track power bus lines and I use 22ga solid wire for track feeders.
The longest bus on my layout was about 45 feet and I used 12 gauge solid copper wire based on conventional wisdom and advice from this forum. Trains ran through that section perfectly well. There were plenty of 22 gauge feeders. There was a minor drop in voltage (about 0.4 volts, I think), but the important thing was that section did not pass the quarter test. So, I rewired it from the far side through the booster.
Conventional wisdom needs to be evaluated on a case-by-case basis.
Robert
On my old layout (25’x50’ w/ a 200’ mainline run), I ran a 14AWG (stranded) bus 150’ from my Digitrax Zephyr and suffered no problems for the 10 years I had it, even with 5 operators running all at the same time. I dropped 22AWG feeders every 9’ and used ScotchLoks to connect them to the bus.
I used no other boosters or even circuit breakers. Just the DCS50, a UR91, and a handful of UP5’s.
I’m quoting Robert but replying to all.
Actually, I don’t need to run 45 feet. I picked that number because I thought it would just be easier to follow the track in a spiral. Truth is I could make 3 18 foot runs and shorten the runs.
A lot of people have mentioned 22 guage for feeders. What I have is 24 guage. Is that too small? I don’t want to sound cheap, but I really am on a tight budget.
I’ll be using the Zephyr and three UP5’s.
I don’t know enough about gauge of wire. But I’ve seen many-many model railroads using telephone wire. Isn’t that 22 gauge? If it isn’t and is 24 gauge, and it seems to work, why not use it. After all, that feeder from rail to bus don’t have to be very long. Would I be safe to say “less than a foot”. If longer than 1’, then go with 22 gauge???
I just looked up CAT 5 wiring:
My box was was purchaced through a contractor outlet and so I would guess it is probably 22 guage. I’ll check the box when I get home. The reason I suspected it was 24 guage is I read somewhere on here that a guy had 24 guage phone wire. That will help teach me not to believe everything I read. Okay probably not, I’m pretty gullible whaen it comes to listening to model railroaders.
If it is 24 ga., I see no problems in using it. Even a bit easier to hide than 22 ga.
Mike.
Hey Mike,
Not to interrupt the thread, but your posts now fit the screen. The links in your signature are gone, though.
Now . . . back to the regularly scheduled program.
Robert
