I understand that the Walthers 90’ turntable in kit form is questionable at best from what I have read in these forums. I’d rather a kit than spend the $200 for the fully assemble with a motor. I like building and a motor is not really necessary for me.
So what IS a good kit form of a 90 foot turntable? What have you had luck with?
Diamond Scale has very nice turntable kits - including a 90’ one. They are not cheap - About $150 for a non-powered ‘kit’. I have a 90’ one with power that I bought assembled at a Train Show for $50! It runs great, so I know they are very good if you spend the time to build it correctly. I wanted a second turntable, and I bought the Walthers one for $200 - assembled/indexes/the ‘works’. Looking at the two models, I can see the value of that expensive Walthers RTR turntable(my time/frustration…).
Close to being finished with the Walther’s TT kit, because neither could I afford the higher priced ones. And you know, I found by following all the advice given in the several threads in this forum on how to make the kit work… it really did on my first try. As others suggested, I used styrene spacers glued to underside of pit to reduce wiggle, made sure a washer separated the wiper bushings, and got the motor cover to fit tightly on the spindle. It weathered beautifully and looks great. Sure, a little noisy, but that’s OK.
Hal, you have me curious - is there a topic in the forum on the Walthers 90’ TT kit? I’d love to look it over (and print it out)… If you have a link, could you PM me with it? Thanks!
Don, good for you! I found that even one nearby sound/DCC engine tended to mask any gear or motor noise on my first TT. If you are in DC and have no sound, maybe a BLI Blueline DC engine is in order since they have BLI’s sound decoder.
I used an unused DC power pack and hooked the motor to the DC outputs. When needing to turn the bridge, a slow dial-up of voltage got the bridge turning at realistic (slowish) speed and it was a pleasure.
I wonder how many people buy the Walther’s non motorized unit and use it for a frisbee. I wouldn’t be surprised if only 3 out of 10 purchasers get it to work correctly. Ok, 4 of 10. The best thing I’ve done so far, at Selectors urging, was to save up and get the motorized indexed unit.
Thank you Crandell, thank you thank you thank you thank you!
Now granted, the indexed model isn’t cheap but being that, on my layout, it is used so much and is the centerpiece of that area, it’s one of the best things I’ve bought in this hobby. If I had to give up 3 dcc sound engines or the turntable and couldn’t buy more of either, the engines would just have to go.
But I hate to talk anyone into getting one because you’ll want to kiss me and I’m not into guys.
Hal - are you still out there? I’m curious too. I have 3 of the Walthers TT kits and I’m just starting to work on them. How about posting a link to whatever advice you found? Please?
“I wonder how many people buy the Walther’s non motorized unit and use it for a frisbee. I wouldn’t be surprised if only 3 out of 10 purchasers get it to work correctly. Ok, 4 of 10. The best thing I’ve done so far, at Selectors urging, was to save up and get the motorized indexed unit.”
Mine would not fly well as a frisbee…it was to warped!!!
I’am in “N” scale at the present,I bought the walthers 130’ compleate,indexin powered,and QUITE it works supper and good indexing.
My problem is the round house.the conerstone round house I have is for the 135’,don’t fit!
atlas round house don’t fit(to narrow).So Iam going to have to scrach build one, to buy an 6 0r even an 12 stall round house It is hard to find an 130’ round house may be some one can help me here?The catalog show round house kits,but does not tell what turn table they are for?
For a very simple and reliable turntable you can build yourself, try the following:
Since the pit seems to be the hardest part to get cut right, you can use a wood speaker ring for the spacer. And maybe for the ring-rail support too. You can get them here in quite a few sizes at a reasonable cost: http://www.able-audio.com/products.php
For the bridge, use a block of wood. Paint it black and glue on some bridge sides and track. Make a top deck of stripwood glued around the track.
For the center pivot, use a quarter inch phone plug. Put the jack in the center of the pit. Wire the track rails to the phone plug, and wire up the jack to track power.
For the ring-rail, take some flex track and cut it in half down the center though the tie strip and lay it around the pit wall in a circle.
You may have to build a small metal plate and use some small screws to hold wheels on the ends of the bridge to ride on the ring-rail.
OK, so you have to push it around by hand, but at least it’s cheap and sturdy. To make it move under power is going to require more tools and know-how. Of course if you do a web search you will find different ways of doing it.
I’ll throw this in since I’m planning on buying a Walthers 90’ kit. Most people seemed to complain that the pit was warped and/or the bridge mounting hole was not centered or defective on the older kit runs. I asked Walthers about this and they told me these issues were corrected on the kits two runs ago. (take that for what it’s worth)
I’d much rather have to make a couple tweaks on an already designed kit than design one from scratch…[2c]
Walthers may have changed their product now and maybe it’s new and improved (and won’t come out of the box warped) but this is my problem with Walthers…
For YEARS Walthers made the 90’ turntable kit with a pit that could not be used as it came out of the box. They knew this and never offered to recall the product or send customers a replacement part. I know that the warped pit can be used after some extensive alterations. By the way, none of these methods were ever mentioned in the instructions or on their web site.
My issue is Trust. Why should I now buy another turntable from Walthers after having wasted my hard earned money on a product that few people have ever been able operate as intended?
The four forum threads I give below describe most of the problems people have had with the Walthers 90’ TT kit. The solutions from the reponders I note in each thread, really helped me get a good working TT on the first try. I tried to follow their advice to the letter, and it works.
The two responses of “nixa1”, and again “Selector” are most helpful
My kit was 933-3135 bought about a year and half ago, and seemed to have had some corrections made by Walthers. Maybe they were listening to “Selector”. It had a washer to put between the wiper bushings to keep the wipers on the bushings and separate. It had screw holes in the motor housing counter sunk… and I did not have the problem occur where the spur gear wouldn’t mesh, and stay meshed, with the large gear wheel.
After reading the above threads here are some notes about what I did. The first thing I did was to cut the hole (after laying the access tracks to align to the center) for the turn table pit. I glued weights under the bridge. I put the pit into the hole I had cut. I stuck the bridge spindle in the pit and spun it for the fit. It did hang up some, so I filed the edges of the bridge that were catching until I could spin it without any hangups. I also placed the bridge deck on the bridge, and checked to be sure i
ThE Atlas TT IS 9", not 90 'feet ', and getting any steam engine & temder to fit on it is big problem - unless you plan to unplug them each and every time - or are you envisioning A STABLE of Russian Decapods?
