Let's turn up the houselights and ask questions
Saw some open hopper cars with bottom dumps. The dumps were open as they traveled. Drying them out? Maybe had standing water in them?
Liquified Petroleum - for making bombs? Said if it leaked you should be a mile away. What do we do with this? It is really dangerous! Probably not as bad as edible tallow, but still… [}:)]
Sign on side of car - Holland Load Snugging Floor Action - what does this floor do?
Optimodal - cute little package - looked to be very heavy - small, fat tank-types - with bracing around them. for???
Saw lots of Kitty Litter (CATX) and…UPS Trucks on flat cars…rub, rub…
That should keep you busy for about 15 min…
Mookie
Sis, I think that’s probably liquefied petroleum gas, fairly commonly transported by rail, and used for lots of different things (including, possibly, backyard barbecues). It’s a gas normally, but is transported in tank cars under several hundred pounds of pressure, which liquefies it. That makes the whole tank act like an aerosol can if it would be punctured or incinerated.
Maybe an old buddy of mine, who works with the Holland Company, can tell me about the snuggly floor. Sounds like it would be perfect for kitties!
The Optimodal thing(y) you saw is probably an intermodal tank container…they’re almost always 20 feet in length, and the framework just makes them rectangular so they can be carried or stacked (with restrictions, I’m sure!) like any other container.
BC
I suspect the hoppers were being illegally moved. All the ones I ever saw had a “Do not move with doors open” stencil on them. The doors aren’t watertight, so any water will quickly drain out anyway.
Can you do the Tarzan yell?
You Carol Burnett fans will know what I mean.
yes, it was undoubtably Liquid propane gas being transported. LPG, the stuff BBq’s run on. it is jsut like butane, it is a liquid when it is sealed off from air, but as soon as air mixes into it, it evaportaes into a gas.
Try this at home… No don’t…
Take a household lighter and ajust the -/+ to the max it will possibly go.
i’ll stop this demontration, i’ll end up getting sued,
lets try anohter,
Got to a variety store and buy a can of butaine. now bring it home, pu***he little nozzel downand spray some onto a peice of paper, it will come out like wtaer, but evaporate within 1 second at most.
don’t use your hands. butane is very cold, and will frost bite your hand!
The big heat plume that just lit up NORAD was not another North Korean railway accident, nor was it the launch of the long feared Canadian nuclear first strike…but kevinsthe1stdegreeburninintensivecareman having a butane incident…
You are so smart!!! That is exactly who I had in mind when I wrote that!
Go to the head of the class!
I looked this up in my haz mat book Ed sent me - it sounded like if this stuff was exposed to just a smile - it would go poof! Driver was reading it to me and included that MIllie should back up about a block, just in case! [xx(]
The “stay away from” distances are for a leaking/burning container (car, etc). The distance is derived form measuring how far away pieces landed after the last one blew up.
A RR tank car of LPG if it explodes (really a rare event) have landed up to a mile away, so they ask people to stay away 1 mile in the event of a problem to put them out of range of the debris.
The Holland Floor is probably some sort of load restraining system that allows the shipper to tie a load down to the floor so it won’t shift in transit.
Dave H.
Good for Driver!
The term is BLEVE when those things go off…You DO NOT want to be there, trust me…Tree68, UniHead & Mudchicken do not want to be there when it’s roman candle time on a massive scale…The stuff is fine until you heat it up or puncture the outer hull of the tank…
Boiling Liquid Expansion Vapor Explosion = BLEVE
I believe Kevin has applied for the stunt dummy job on the Red Green Show?
Rusty Iron Feathers[:-^][:-^][:-^]
Shall we send Kevin to THE COUCH IN THE CORNER for this[?]
Mookie
better keep them eyes open on those UPS trailers.A guy told me he saw a container open and boxes flying out of them.was spotted by another crew train stopped and problem fixed.[:0]
stay safe
Joe
I know about the tanks…I think they were UP’s “Bulktainers”. Hope this helps. [:D][8D][:)][:p][}:)][;)]
Mookie,
LPG, Liquified petroleum gas, butane, propane, those guys.
Carl explained, its a gas at atmosphere, but under pressure, is a liquid.
You know the little bottle of propane driver has hooked to the torch he uses to solder, or the bigger bottle under the bar-b que pit?
That stuff is a LPG.
Mudchicken told you what we call it when one blows up,
Bleve.
If you do manage to poke a hole in the side of one of these, the friction of the liquid against the edge of the hole, added to the rapid expansion of the liquid into a gas, can/will cause it to explode.
Think about it, we have a offical name for one of these things blowing up.
Englewood had a bleve back in the 70s, after all the fires were out, and they found most of the cars, they ended up bulldozing most of the north side of the yard across Liberty street, into a empty lot, and starting over on rebuilding the yard.
Yes, they can throw parts of the car a mile.
We saw a bleve in our training films, the tank went pretty much straight up, about 100 feet, landed several hundered feet down range.
Now, after telling you all that, heres this.
Carl, Mudchicken, LC, wabash, me, Rodney Beck, and now, N Stephenson, all work around this stuff every day.
We transport thousands of the LPG tankers through “your” town every day.
I kick them, in cuts of two, all day long.
Because the tanks on these cars are tough, real tough.
I am sure Muddyfeathers can give you the math and specs on one, but they are designed to be beaten to death.
We are trained on how and where to place them in a train, so they dont get a hole poked in them.
Because the people who build the tankcars, and because we railroaders do our job every day, and do it right, you most likely will never see a bleve.
Holland load snugger floor, floor has slots in it, to allow a eyebolt type device for straps to be sliped into the slot and locked in place, allows you to strap and
I also saw a training film on Bleve’s; it was a news film of some “On The Spot News” reporter talking with a fireman while a tank was exhausting flames from a hole in the side. In mid-sentence the film whited out as the tank launched. Everyone in the area was killed. The point of the film was to give these things lots of room. (Hmm, like I was planning to interview the firefighter myself. I don’t think so.)
In the fire service we used to refer to a BLEVE as a “Blast Leveling Everything Very Effectively”…
LOL!!
LC
Look i’m goignt o put thsis so a 2 year old can understand it…
light a mtach near it, if it goes boom, it was gas, if nothing happens, try to surpress the feeling of being gyped, for it was nothing.
oooo Ed put it so sophisticatedly… Heres how you can find out… this is out oif my book of rules… Take an ordinary butaine lighter at home. turn the +/- all the way to +, matter of fact break that little black thing and take a penknife and keep turning it a few more turns.
Okay, now whatever you do, DO NOT LIGHT IT! press down the gas. You will notice the gas is comming out so fast, it will coem out as a liquid form, then quickly evaporate.
that is the sciece of things.
PROCOR tanks, are tough, really tough indeed. they can survive a good blow.
So kevinsthesoontobeburntoacrispman is going to be made a BLEVE(r) in the incidenary power of compressed gas…
headed to the couch…
oooooooooooo. FIRE. if you ever are in an emergency situation and need napalm (and i mean ONLY in and emergency) cover styrofoam with nail polish remover, wait one minute, mix ensuing globs with diesel fuel (don’t use gasoline, thats not safe) and light and fling. I remember when i did this one weekend… never mind that was a bad weekend.
Safety First
Adrianspeeder
Only if Kevinsthecrispyrrman takes the Last Train to Clarksville, the he can say I’m a Bleve(r)
Ed
