I just purchased an LGB 2119D loco and have a couple of questions. I tried searching and found nothing. I received no instructions or information about the unit and am having trouble finding out how it all works (like the 0-1-2 switch on the back of the cab).
The loco is quite dirty. Can I spay it with a cleaner like dish soap and then rinse it off? It is for outdoor use after all.
Can I add sound to the unit? The tender is empty and there is a connection between the loco and tender. Can I transfer the sound unit from my Bachmann to the LGB? Would I just attach the black and red from the Bachmann to any of the black and red on the LGB? What is the purpose of the apparent connection at the back of the tender?
Yea… I am over there too. Apparently the 2119D is some sort of rare mogul with little to no information available. I “searched” 2119 and got ZERO results. I went ahead and transplanted the sound board and speaker (which is waaaaay to big!) to the tender of my 2119D. I just wired the black to black and red to red wires. I am curious as to the purpose of the apparent plug at the rear of the tender.
All LGB loco have the two plugs on the rear of the loco or tender. They are for lighting trailing cars. You just have to be careful on the polarity so you don’t short things out.
Wellll… I apparently burned out the circuit board. I heard a “pop” followed by a whiff of smoke from the tender (where I mounted the speaker from my Bachmann). Do any of you know where I can get the board? I’ve been looking and can’t seem to find the board. It’s the square board not the “Y” shaped board.
The “Y” board connects to the engine cable and has 8 connectors on the rear. The other board is a tan colored, single small square with red and black wires going to and from an “outlet” at the rear of the tender, (IIRC) wires connecting to the “Y” board and a loose black and white wire. The board just site loosely in the tender.
Could this have been something the previous owner added? Did I REALLY screw things up? Can I post a pic here?
NEVERMIND… I’m such a dufus!! It was the Bachmann board I burned-up. I just took a gander at the picture I took earlier and there is no such board! I will remove the Bachmann board and move on!
