Hi, Im trying to add decoders to a dual gearbox LGB Union Pacific F7A/B set and the instruction manual says: “has two “D” gearboxes and decoder interfaces. It can be equipped with two LGB MTS Decoders (55020) using one decoder interface cable (55026)” This is confirmed by the 6 dot star on the gearboxes.Can anyone give me some tips about connecting 2 decoders to the 1 PCB? It looks like the interface cable can go to one decoder to set up the function and light control, but im not 100% sure about the track to motor connections from the decoder, do these go to the 2 rows of pins next to the current track/motor connectors on the PCB? Is there any links you know of that give a tutorial on this kind of installation? Any help appreciated, thanks, Dan < |
Hi Dan, As you do not show where you are its difficult to help, You may find a member or a retailer close by that will have a wiring diagram that will help you out. If you are in USA then try garden railways mag or in UK garden rail mag Do get the right info or risk a large bill if you get the wiring wrong. Hope this helps
