I want to create an out-of-sight storage siding wired as follows:
I want to be able to turn power on and off to the siding as a separate block - Do I just use plastic joiners in one rail and put a toggle switch between the power and rail?
Since the siding is out-of-view, I’d like to have an “indicator light” that comes on when the train approaches the end of the siding -What is the best way to “activate” this light on the control panel?
You could use a pressure switch under the rails so weight of train activates the light. Maybe 50% reliable, requires constant maintenance. You could use an IR emitter and receiver. You’ll have to ask the electronics guys how to do that. Maybe you don’t need the light. It appears to me that your intent is to stop the train at a specified spot. If that is the case, reduce the length of isolated rail to the length needed to stop the engine. Train will stop at the desired point automatically. Hit the power switch to have the train start movement again.
Besides wanting to know DC or DCC, is this a dead end spur or a real siding that re-joins the main line?
If you did it with a single loco at the head end and you are using DC, a single gap and a diode would make an automatic “stopper” that would kill the loco at a certain point, but allow you to reverse out.
