lichen
years ago the method used for softening and preserving lichen was to use glycerine. any alternate methods floating around?
jon in tennessee
it was simple and worked.
nowadays most people buy precoloured stuff which is more expensive but easier to get hold of (in a city at any rate) and doesn’t fade with time if exposed to UV light.
Nowadays most people don’t even use lichen anymore. It’s not very realistic. They use ground foam, mostly.
thanks for the posts. i thought i might use some as it grows all over the place here in southwest tennessee.
jon in tennessee
I gathered up a ton of lichen on a trip to Maine a few years ago. I got a gallon of glycerine through a medical supply pharmacy back home here in Connecticut (they supply nursing homes with stuff- also a good source for plaster gauze cloth…) and boiled the lichen. It has stayed soft for the last 5 years. I sprayed it with some cheap green spray paint (Krylon in a can) and then did the matte medium-ground foam-matte medium thing. I’ve been really happy with the results for covering large areas of background on my N scale layout.
The stuff grows all around the place where I live. Carefully selected, they make good models of shrubs of the type common across the western US.
Michael Loik
Ben Lomond, CA
It’s Dirt Cheap at Hobby Lobby. Sold in the floral section as deer moss. Seems to be cheaper than the chemicals and colors needed to make it. Is still a viable scenery material. FRED
I beg to differ, if use correctly. In N scale I use it for the bushier portions on the upper parts of live, growing Summer deciduous trees and I cover it with ground foam to simulate leaves. I agree that the old fashioned way of using it alone with nothing covering it did not look very good, but with the ground foam foliage It looks very nice.
Ron
Ron
