Is it possible to convert it to DCC?
Has an 8 pin socket in the tender.
David B
Would it to be possible to convert a 0-6-0 life like saddle tank?
There isn’t any room in the engine to put even a small DCC decoder, so you’ll have to permanently couple a freight car to it. If you use a freight car with metal wheels, you can improve th electrical pickup at the same time. That would help it out a lot.
There are some locomotives, such as your saddle tank switcher, that are just not worth the time and effort trying to find a way to install DCC.
Mark Watson, over on the Trainboard forum, posted several threads on how he “ultimated” his 0-6-0: installed decoder, remotored, added headlight, improved gearing, etc.
You can see a video of it in action.
At some point I’d like to do this myself, so I’m looking forward to seeing your efforts!
