Life-Like Proto 2000m Series GP-9
Have the above engine with a bad decoder. Can anyone tell me how to get the shell off the frame? Do not want to get too rough with it and cause more problems. Thanks for the help.
First remove the front and rear couplers. Then the fuel tank. You will see 2 screws to the rear of the fuel tank next to the AIR tanks, then the shell should come off. The fuel tank is held on with stick tape inside.
Bob
