I want to cut down the o/p voltage of my transformer by 2-3 volts to slow the train down but yet enabling my grandson to use the full throw of the throttle… What can I use to accomplish this… I tried a resister and it worked but prevented the horn/whistle from operating. Would really like to have the whistle function and keep the train on the track… Was thinking of trying a house dimmer inline with the output line to the track… Any help would be appreciated. This application is for a O gauge setup steam engine using a Lionel CW-80 transformer.
Rob, I started to suggest that, but I hesitated because he says he’s using a CW-80, which makes the DC voltage component to blow the whistle by differentially offsetting the turn-on times in the positive and negative half-cycles of the waveform. Reducing the waveform voltage, whether with diodes or the resistor that he tried, will also reduce the DC voltage component that the offset causes. The diode scheme does this by subtraction of voltage instead of multiplication, which might make it marginally different; but I am not optimistic about it. The same consideration applies to lowering the line voltage supplying the CW-80.
Traditional Lionel transformers avoided this problem by switching in the separate 5-volt whistle winding.
I don’t have a CW-80 to experiment with; but I wonder whether simply offsetting the handle on the speed potentiometer would be hard to do. Perhaps someone familiar with that can post some advice.
I’ve got diode strings in the downhill block of my layout powered by a CW80. With a Railsounds tender, the whistle and bell still work. A tender from circa 2005 with a motor type whistle works on this set up as well.
Although there are a number of ways to control maximum speed, one of the great advantages of bluetooth based app enabled speed control is that maximum speed can easily be set for each individual loco. Also, the reaction to throttle changes can be adjusted on both speed increases and decreases. Very useful for keeping things under control.
