My 151 dances when activated and upon further review, the gears are worn on the arm and the other part. I’d like to replace both. Any place to get the part #s and then a dealer?
As always, much thanks
The Train Tender has both the 151-10 rack & 151-11 arm, $2.75 for the set. The rack rarely wears out.
Rob
Thanks Rob. You’re right. I don’t need the rack, only the blade. That’s what’s worn. How easy is it to remove the rivet on the blade to switch out the gear? Doesn’t look easy. Shoulda been a screw! Can just the gear be replaced or do I need the whole blade?
Thanks
trainbrain,
Use a small punch to drive the pin out of the blade. When you install the new blade, use channel lock pliers to push the pin back into the blade.
Jim’s right - it’s a press fit affair, and the gear & arm are 1 piece.
Rob
Thanks Jim & Rob-I punched the pin out so I just need the new blade. Will call The Train Tender tomorrow.
Brian
