Well, here we go again with “Senior Moments”
Just picked up a Lionel Block Signal 153 (used) and attached it to a 153C Contactor.
The green light displays and the red light comes on when the train goes over the contactor and goes out after the train passes.
Question: Throughout the entire operation, however, the green light stays on.
Is this normal or should the green light go out while the red light is on?
(I’m pretty sure I followed the wiring instructions but, then, these senior moments do pop up)
As always, many thanks.
Only one light should be on at a time. The two outer terminals of the 153 should connect to terminals 1 and 2 of the 153C, which are the two 153C terminals that are on the same side of the 153C. Then the center terminal of the 153 and the lonesome terminal 3 of the 153C connect to the power supply.
Unless someone has rewired your 153.
Bob: Thanks. Like I said, it has been used. I’m sure the wiring hook-up is ok. I’ll recheck the actual wiring. Thanks, again.
Bob: Problem solved. I changed the 153C contactor and all is OK. Thanks, again.
