Hello: I am looking for a part for the 164. It is the wire directly under the roof with insulatorsat each end that supply power to and connect the two light bulbs with the wire that is soldered to one end and goes down the post to the power connection. It might properly be called a light fixture power rod. Does anyone know where I can purchase one or who can make one for me. I may also need the entire green base. Can anyone recommend someone who would have them? Thank you, Joe
Joe - Welcome to trains.com! [C):-)]
If I can’t find stuff like this, I tend to fabricate my own.
Are you interested in doing one for me and what would it cost?
The part is number 164-50 “Connector Wire Assembly” or “Light Connecting Wire Assembly”.
The only place I have seen this part stocked is at Lionel Train Parts.
Thanks Rob. Found it. It is on his parts lists but now we will see if he has one.
