Lionel 2023
I am new to Classic Toy trains but the terrific info on the forums made me create an account. I am looking for a solution. I recently acquired an old UP Lionel 2023 powered and dummy unit. When I apply transformer power, the E-unit will engage (click up), buzz and the headlight will come on, but there is no sign of power to the engine or the front drive wheels engaging. I have the shell off and have reviewed the wiring diagrams. Any ideas of what I could try get this loco moving?
After checking for loose wires the very next step is always the E-unit. It could be dirty or have broken fingers, a visual might spot it. Parts are available if needed. Also check the brushes and springs.
Three things to check for:
o A broken wire, which may appear connected if the insulation is holding it in place.
o A finger in the e-unit not making contact with the drum. If this is the problem, you may be able to get the motor to respond by poking the errant finger with a toothpick while power is applied.
o Worn out or missing motor brushes.
You can rewire the motor for test purposes to bypass the rest of the locomotive: Connect the field winding to one of the brushes. Connect one transformer wire to the other brush. Connect the other transformer wire to the motor frame, which is the other end of the field winding.
Thank you Sir James. I have swapped an E-unit in a steam Lionel. There has been some previous work that I can see with some solder. I will do some more tinkering. Thanks for your direction.
Derek :slight_smile:
regards, Derek :slight_smile:
Hi Bob,
I have read your previous posts on lionel 2023. Thank you for your reply. The E-unit appears to have only one finger? Many wires soldered to it. The E-unit looks like the original according to the lionel repair book but I guess I could swap it with another E-unit I have. The coil wires (yellow and blue) travel along the engine down across the top of the E-unit under the clip to the rear truck. If I can get the engine to come to life and the wheels to turn that would be good. I took the top of the engine off and the brushes (little cylindrical copper pieces) are there and intact. I cleaned the armature turns fine. I gave the brushes a little cleaning. I will give it ago with your suggestions tonight to bypass the rest of the locomotive. I appreciate your reply.
regards, Derek
[#welcome] aboard!
Becky
Thank you and regards! [:D]
Derek
I don’t understand several comments in your last post, Derek:
There are 6 fingers in the e-unit, not 1. These small copper-colored strips are fastened to 2 small circuit boards, 4 on one and 2 on the other. Their free ends rub on a small plastic drum, making contact (or not!) with copper sections on the drum as it is rotated by the pawl.
The yellow and blue wires should go from the e-unit to the motor brushes, not to any coil.
The brushes are indeed little cylinders, but carbon, not copper.
When you rewire the motor for testing, disconnect all 3 of the motor wires. (You can leave the connection between the field winding and the motor body.)
Here is a link to the wiring diagram:
http://pictures.olsenstoy.com/cd/locos/loc2023a.pdf
When you reconnect the motor, the green wire goes to the center motor terminal, for the field winding. It doesn’t matter which of the yellow and blue wires goes to which brush holder.
Hi Bob,
Thanks again for the input, anatomy lesson on the e-unit and your suggestions. I removed the e-unit last night and now fully understand “fingers”. All of the wires in the e-unit are green with oxidation…even when stripped back…that explains no electricity to motor. I wired directly to the 2023 motor bypassing the rest of the locomotice and touched the transformer leads…it grunted, buzzed and the armature is trying to spin…so at least I know the it is probably oxidized wires (probably original). I ordered another clean e-unit replacement on Ebay. My goal is to rewire with new wiring and go from there. I will rewire according to your diagram. The new e-unit has the three(3) color coded wires. Yellow and blue for brush holders and green for the middle connection or motor winding. Does this sound correct?
Original Postwar Lionel brushes are often copper colored due to high copper content in their composition.
Thnak you CW. I am definitely learning as I go. This is a great forum.
regards, Derek
Hi Bob,
I am happy to say that my Union Pacific lionel is running strong! [:D] I appreciate your advice and suggestions. Here was the core issue…broken wire from the motor coil winding located directly UNDER the green wire…I just never realized the significance of that wire since I did not have a motor diagram for reference or repaired a 2023 before. Of course I learned this after I replaced the e-unit and did some soldering…but that is how you learn, right My last question concerning the motor. On top of the motor, it say “oil”. Should I add a few drops to this circle area?
regards, Derek [Y]
Hi Bob…found the motor wick oiling diagram for the 2023 motor…
http://www.justtrains.com/Service/maint-12.asp
Derek [Y]
Here is another great place for info.
http://pictures.olsenstoy.com/searchcd1.htm
For the 2023
http://pictures.olsenstoy.com/2023.htm
