The headlight on my Lionel 2026 stopped working. Any suggestion of how to fix this would be appreciated.
Thanks, Roop
Thanks, Roop
Under the front there is a metal bracket held on by 2 screws that the front truck attaches to. Take the screws out and lift the bracket straight off. The light bulb will drop down with the bracket. The problem could be a loose wire, but it likely just needs a new bulb.
Trevor
Great! Thanks.
Many times these old wires have rotted and are shorting. Look carefully where the wire passes into the lamp housing and where the wire goes into the pad that the bulb sits on.
Roger
Appreciate your advice. Thanks.
Headlight wire looked fine and the connection also seemed ok. However, I had a new E-unit installed a while back and this is the first time I tested the train since the installation.
I am wondering if wires were crossed during the installation. Does anyone have a wire diagram to share that shows how the E-unit, smoke stack and headlight wires are connected?
Thanks.
Thanks.
I don’t quite understand the diagram, but I will try to work with it.
The headlamp wire connects to the lug on the side of the e-unit (not the fingers), next to the lockout lever. Power to the e-unit coil, track pickup lead, also go there.
If it were me, I’d take the locomotive back to whoever installed the e-unit and tell him what you just told us.
Ah hah! Currenty, the headlamp and smoke wires are together – on the left side of the e-unit if I am looking at the back of the train.
You are saying the headlamp wire should be on the right side. Don’t quite understand what the fingers are
Thanks
Unfortunately, that store closed.
Thanks.
That’s fine - the smoke unit, center rail rollers/collector, headlamp, and e-unit all make their connection at the same location(electrically, anyway, and usually physically too).
Oh, ok.
Then the problem may be the e-unit itself, even though it was supposed to be a new one. Sigh!
Thanks Rob.
The E-unit operation is completely separate from the headlamp.
And for a minute there, I thought I knew what I was talking about.
Perhaps, I should try to locate another lionel train repair shop…
If it’s the wiring maybe some images of what you have might help. I had a whistle problem a while back and I took photos of the board and wiring and someone spotted the problem in the photos. Good luck!
Good idea.
Thanks.
Use the macro(the little flower icon) setting to get sharp up close pics.
Have you tested the bulb yet?
Yep. The bulb works fine.
