Lionel 2332 Headlight Bulb
Are there any other bulbs that can be used in a Lionel 2332 besides a 756 and 1456?.
1456 are difficult to find.
Doug–have you searched at Trainz? I just did a search and they have both the 756 and 1456 bulbs available.
Thanks, I will check it out!
Thank you!
My go-to parts supplier is Jeff Kane at The Train Tender. He has the correct bulbs listed, 433-300 (equivalent to the 1456).
For the record, 1445 bulbs should work in the 2332 without issue- they simply have a smaller sized “bulb”, but have the same style bayonet base and are rated for the same voltage.
-El
I didn’t know about the 433-300.
Thank you for that.
