In rebuilding my single motor 2333, I have a wiring/polarity issue in that the headlight, which normally works when the black wire is soldered to the red wire on the enit, only works now when I touch it to either neutral outside rail or the metal part of the truck(only the middle part of truck, ie., stainless steel pin that attaches the truck to the body or the ‘block’ piece of the same metal behind the pin.
Of course it was working fine a few days ago wired directly to the e unit in tandem with the red wire from the pickup line. Hve I somehow reversed polarity int the front truck magnet or somethong else???
Mark B.
