Lionel #254 Engine
Hi,
I just bought a Lionel #254 Engine that will not operate in forward or reverse. The engine has been rewired and the brushes look good. The engine made one mad leap forward when I first put in on the track, but I quickly pulled it off the track so it didn’t collide with its passenger cars. I used the manual reverse lever to reverse direction of the engine, and since than the engine will just make a slight hum or buzz when power is applied to it. The field coils seem to get pretty hot. Could the manual reverse unit be bad?
Does anyone have a wiring diagram for this manual reverse unit so I can see if it is wired correctly?
The motor appears to be clean and good shape.
Thanks Again,
John
Here you go: Olsen’s
Thanks again Rob, your link for the manual reverse unit wiring diagram corrected my 254 engine wiring glitch,( see other post).
The engine runs smooth as silk.
Thanks Again,
John
[Y] [:)]
