If, like me, you encounter serious sticker shock at the price of lighted FasTrack bumpers (and have doubts about how well the little beggars would hold up under repeated batterings from, for example, bump-and-go trolley cars), here’s a simple. inexpensive alternative using materials already on hand…
Materials required:
Lionel #260 Bumper (dime a dozen at any respectable train show)
Piece of FasTrack (likewise)
The 260 comes in two flavors: The O/O27 version and the later Super O version, with smaller rear tabs.
http://www.postwarlionel.com/cgi-bin/postwar?ITEM=260
In this case, I used a Super O version, as it was easier to;
Step 1) After taking the screws out, remove the bottom lugs on the bumper, as shown here with a unmodified bumper for comparison:
Be careful when cutting off the front lugs that you don’t cut into the threaded holes for the screws. Don’t ask me how I know this, please. [:$]
Step 2) The rear of the bumper has a pin mounted in it. When dealing with tubular track, this pin is slipped under the railhead to hold the back of the bumper in place. Since FasTrack has a rectangular rail profile, a careful, detail oriented craftsman will drill a precise 3/32" hole in the side of the rail, into which the pin neatly slips and holds the bumper firmly in place. If you’re like ME, however, and you already have that loverly fiber reinforced cutting wheel mounted in a nicely warmed-up Dremel, you just hack a notch in the rail, thusly:
