Found a 317 trestle bridge that, for all intents and purposes, should have been left in the trash BUT I couldn’t resist the temptation with grand thoughts of a restoration project.
So, here’s the question: What would you suggest that I use to strip the remaining paint and to remove the rust? (The structure itself seems to be intact.)
As always, many thanks.
As the bridge is metal most anything can be used to remove the paint–people use brake fluid, oven cleaners, 91% isopropyl alchohol or a regular paint remover.
For the rust the best thing I’ve used is Evapo-Rust available on the net or at many auto parts stores. Removes all the rust and doesn’t harm anything else, no fumes just soak the parts.
Scotie
Scotie: Thanks for the advice. Will try and see what happens.
By the way, this bridge is an example of a Lionel misnomer: It’s a Howe through-truss, not a trestle.
Bob:
Appreciate the note. Always glad to learn something new about the hobby.
PS I certainly hope that, after I work on it, it will still resemble a bridge (any kind). Thanks.
