Lionel 364 log loader belt replacement
Can you give me some tips on the best way to replace the belt on a Lionel 364 log loader? How is it fastened together to form the loop? Thanks.
It comes as a continuous loop.
The detailed instructions are HERE.
Rob
Rob:
Just joined the forum. Need to replace 364 log loader belt. Not clear on how to remove the rollers/pins. Can the reused? If not? Where to get replacements? Tks
Jeff kane at jeff@ttender.com or 1-585-229-2050
If they cannot be freed up with PB Blaster for removal and cleaning, then replacement with repro parts is in order. The Train Tender is an excellent resource.
