Weird one here. Loader was operating fine. Have it hooked up to a kw 190 transformer (second power supply - not continuous but the one that allows variable power). Suddenly stopped for no apparent reason.
If I touch the common wire directly to the motor - (while leaving power hooked up to post) it will run perfectly. But If I connect the common wire to the actual post - I get nothing.
It does not look like there was a wire going from the common post to anywhere on the engine, the post is just riveted in.
The whole chassis is common and you seem to have an incomplete connection at the base of the post. Try taking a center punch or nail set and strike the underside where the post connection touches the sheet metal. You could also connect the common wire to the terminal post and briefly touch the positive to the rivited (or spot welded) underside in an attempt to “spot weld” the incomplete connection.
Thanks for the suggestion. I wound up running a wire form the common post to one of the screws on the underside where it mounts the engine to the base. When I connect the common wire to that post it now works fine. I am thinking maybe the vibrations worked the rivet loose??
Bad grounds are a common problem. Corrosion, loose connections, and even carbon from arcing can cause resistance which will stop electricity from flowing.
