Hi, I acquired a Lionel MPC Santa Fe, 8020 and 8021, boxed set # 6-8020. The A&B units both have a wire coming out of the rear/front port hole and connect to each other with a little yellow banana clip. The wire powers a light in the “B” unit. My question is was this set altered or is it original equipment. Also I believe the E-unit is not the correct one for this diesel as the lever is pointing down and not coming out of the slot on the top. Any information on this set will be greatly appreciated.
If you go to Lionel’s web site and search under owner’s manuals for the 2 numbers listed, it appears that who ever had the units before you did some alterations as the parts diagram shows the e-unit lever pointing up in the A unit and there is no indication of a tether to the B unit or a lamp in the B unit.
It’s altered. Probably done when the 3 position E-unit was put in to replace the original 2 position. Does it still have the MPC power truck w/ traction tires & the double wound field?
First of all, Thank You to everyone who helped, I suspected it wasn’t original. It does have the Power truck w/ traction tires but I don’t know what the “double wound field” is.
