I’ve just taken delivery of a new Lionel All Hallow’s Eve locomotive. It looks great and seems to run more smoothly than my Harry Potter locomotive which it is based on.
I am having trouble coaxing all of the ‘scary sounds’ out of the thing. It is supposed to have a werewolf howl for the whistle, a scream for the bell, and a witch’s cackle for the brakes.
All I can get is the scream for the bell. It is the same whether I run the locomotive using my Legacy / TPC combination or a CW80. The scream swaps between the whistle or bell button on the CW80 when the ‘neutral’ terminal on the CW80 is swapped between the center rail and the outside rail - as it should.
Running the locomotive at high speed then suddenly slowing does not produce the witch’s cackle.
The general background ‘scary sounds’ work just fine. In fact, I wish there was a volume control for them.
Anybody else seeing this problem with their All Hallow’s Eve locomotive?
Another conventional control locomotive I have with bell, horn and brake sounds operates as it should.
I think I’ll have to make a call to Lionel Service and probably end up sending it back.
Thanks.
