lionel engine porblem modern era Alask 1804
I’m guessing you have IE9. Find the compatibility icon to the right of the address bar. It looks like a torn piece of paper. Click it once. You should be able to post then.
Jeffery, let’s see if it posts now. My engins, like new hardly used quit running. The little gears on the motor shafts ame loose and the gear they drive is stripped. Any solutions? Is there trucks with metal gears that are compatible? Thanks for reading.
