Is there an easy way to connect K Line snap track to Lionel Fastrack?
I have seen snap track to tubular track adapters but nothing that converts to Fastrack.
Thanks
You could go Snap to Tube to Fast if you have the room.
Cut the connectors off the snap-track, and use the fastrack transition piece between the two.
Like mpzpw3 mentioned cut the ends off the snap-track and use the O gauge transition piece. Snap-track was K-Line’s new track in O gauge before K-Line went under, looks like GarGraves track base and O gauge tubular track thrown together.[2c]
Lee F.
just get a fastrack-tubular adapter. You can use regular old pins in the snap track same as tubular track.
