lionel legacy cab-2
Have Lionel Legacy cab version 1.52 system. Can’t figure out how to access the cab 2 function. Trying to run a Lionel Canadian Pacific Lionmaster SD-90 Diesel Locomotive 9108 TMCC. Can run it on cab 1 but cab 1 does not access all features. Sure isn’t the same as running post war setups. O the good old days.
Thanks
Barry
Is it a Legacy engine? If not it has no Legacy features.
thanks for your reply… It states…
TrainMaster Command Control, and…
  • RailSounds sound system with CrewTalk communication and TowerCom announcements. So, should be able to run the rail sounds… does not state legacy system… what ever help is appreciated…
  • Thanks
  • Barry
it will only run in the cab1 mode if it doesn’t have legacy.
ok, thanks for your quick reply. Now still have to figure out how to run the rail sounds with crew talk.
Thanks
Barry
in cab1 mode it should run the railsound and crew talk
Success!! Found a you tube on how to program the legacy remote in CAB 1 mode to match your TMCC locomotive and we are rolling railsounds and all…
Barry
