Lionel Niagara Problem
HI GYZ,
Put my Lionel Niagara on the tracks last nite. Powered it up the normal way with ZW and Legacy. I have power going to tracks 1 and 4 that I control with the cab2 to run conventionally if I want to run conventional engines. I ran it for 5 minutes all good then it stopped. I shut off power then checkit all out seemed like nothing wrong. Placed back on tracks powered back up and it started out in conventionally. Shut off and tried to reprogram,but when I powered it back up still was running conventionally. It runs great in this mode save for the bell and whistle I have none of them. Has this ever happened with anyone? Is there a quick fix?
laz57
im not sure its the exact problem you are having but similar. even with the legacy on, powering up the track cause everything sitting on the tracks to take off in conventional. i also noted that if the track power was off and i turned on the legacy, what happened is what ever locomotive was selected, the bar graph just started moving up with no command. i finally put the base unit module in the slot and powered down and then up again, seems to have taken care of it for now.
