Does anyone know if the small wheels on the original Lionel fork lift truck are supposed to roll? I recently bought this accessory and the link arm doesn’t move all the way to the end of the unit as it’s supposed to and wonder if it’s because the small truck wheels are locked. Without the fork lift truck on the pin, the arm moves as it’s supposed to. The manual says that if the arm doesn’t go all the way to the end, to bend the arm or adjust the spring tension.
Thanks,
Rod
