I can’t find a parts dealer with the 44-53…LAMP SOCKET COMPLETE
Anyone have one or know a parts dealer that does?
WHAT is this from? Give more information please.
Roger
The socket is for the #44 Missile Launcher. Have not been able to locate it either.
Larry
Improvise. [:)] I’m sure you can find something that will work and do the job.
Jeff didn’t have the part listed, I checked. [;)]
gunrunnerjohn,
Thank you for the update.
I thought of Jeff, because he usually has most parts.
Ralph
He’s my first stop looking for parts. [tup]
Call him. Not everything is listed on the sute
Ditto on giving him a call. I was pleasantly suprised a couple of times.
also he has a lot of knowledge and will tell you about subs if he can think of one
You might try calling Chuck Sartor at Mizells trains in Denver. He has things others don’t have.
Roger
I may have found a suitable replacement for you that you could adapt. Part is 68-92 Lamp Socket Assembly for the 68 inspection car that takes the 2 pin bulb. Don’t know what you would have to do to wire it, but I did find it at www.smittystoytrainparts.com for $3.00. It appears that it is the closest you can come to the actual part you need. Good luck if it decide to order it, and if you can adapt it.
Teledoc (Jerry)
