The other day I was running my 2055 with no issues, derailed the trailing truck while trying to back through a switch [:P] , then decided to call it a day. A bit later I i was was running it for a minute or so but when trying to go into forward from neutral it barely moved (of course I could still hear the motor humming), then it ran backwards for a bit, tried to go into forward again, same thing, then wouldn’t budge in neutral. Hoping its nothing serious such as a gear tooth broken or something (ive got a K-Line MP15 on my workbench with some seriously screwed up metal gears). Anything to look for, I’m sure its not an issue with the E unit because the wheels no longer turn freely when I try and move them manually.
Check your gears carefully. Motors locking up as you describe is often caused by something lodging in the teeth. When this happens the wheels will turn a bit, but then almost always freeze in one spot.
If the wheels are hard to turn all the time, then somethng (like a piece of tinsel or carpet fiber) might be caught on an axle, usually between the wheel and frame.
Often these bits can be plucked out and unwound with a very thin pair of tweezers.
Well it seems to have cleared up after manually getting the wheels to turn, then running it for a bit. Definitely could use a little cleaning around the axles from what I can see. It figures though that something would happen just over 7 days after I got it (was purchased off eBay with a 7 day return policy)
check that your drivers are secure on the axles. I have a 675 that looked up, and one of the drivers was loose, and got out of sync with the gears. a drop of super glue fixed it.
Same problem on a 1666. Found the driving rods were loose on one side. Got them back into position and presto - smooth running. Now after a few hours of running I check all the rods for tightness.
