Would it be possible to substitute at Lionel 622-100 for a 2028-100 motor. Are there any differences between the tow?
From what I could fine in the repair book:
Seems there are two motors for the 622. 622-100 and 622-100X they will not exchange with each other. The 100X fits only the 1949 model 622 so you would just need to see by giving it a try if your not sure what year 622 you have. The 2028 was from 1955 and may work in the 1950 622.
Looking at those motors on E-bay listings it don’t look good. They seem to be different on the bottom castings.
Thanks Kev. I was thinking of using the 622-100 from the 1950 version. You may be correct in saying the castings are slightly different between the 622-100 and the 2028 used in the GP-7’s. I had a feeling they may be somewhat different. but doesn’t hurt to ask.
Ed
The designs are very different: The geep trucks had the motor shaft running through the center bearing, while the NW2 trucks’ center bearing was distinct from the motor shaft.
O.K. Thanks Bob. Appreciate the feedback.
Ed
