Lionel pre-war type "T" transformer
I have an old pre-war 100-watt type “T” transformer. Used it for accessories years ago, but its been sitting since. I gave it a new power cord. Voltage on all posts tested OK. I hooked it up to a track, and at the lowest variable voltage (maybe 5 volts) the locomotive flew. Had I not immediately shut it down, it would have landed on the other side of the room. And this was just a little scout steamer.
I never tried to run a train with this transformer before. Anybody have any ideas what is happening here?
Thanks.
What terminals were you using?
A and U.
That would give you 17 to 25 volts. No wonder your locomotive behaved that way!
Try B and U, for 10 to 18 volts; or C and U, 2 to 10 volts.
Bob,
I don’t have any documentation for a “T” transformer. I just hooked it up like the newer stuff. It sounds like the “T” transformer is different. Or is this rather a characteristic of pre-war transformers?
There is a long list of terminal combinations and voltages on the nameplate, as you might imagine is necessary with the 9 terminals of the T. In case the fine print of yours is illegible, here is what mine says:
C TO D 2 VOLTS
C TO E 4 VOLTS
C TO F 6 VOLTS
C TO G 8 VOLTS
C TO H 10 VOLTS
B TO C 8 VOLTS
B TO D 10 VOLTS
B TO E 12 VOLTS
B TO F 14 VOLTS
B TO G 16 VOLTS
B TO H 18 VOLTS
A TO B 7 VOLTS
A TO C 15 VOLTS
A TO D 17 VOLTS
A TO E 19 VOLTS
A TO F 21 VOLTS
A TO G 23 VOLTS
A TO H 25 VOLTS
VOLTAGES OBTAINED WHEN USING SWITCH
C TO U - 2-4-6-8-10 VOLTS
B TO U - 10-12-14-16-18 VOLTS
A TO U - 17-19-21-23-25 VOLTS
Bob,
No, I can’t make out the writing on mine. Thank you for the list.
