Does the Sante Fe 212 Diesel have a horn? Thanks much, Jake
David Doyle’s book say’s yes
How is the horn activated? I have a new MTH tranny with the horn/whistle button, but it does not seem to work the horn, Thanks, Jake
the 212 was made in 1964-66 before electronic horns. you have to remove the body shell and if the horn unit is still in there you insert a size C battery. It is actually a bicycle horn. Then if everything is still in working order, your horn or whistle button will make it sound.
Thanks for the info on this, I apprecaite the help, Best Regards, Jake
