I was flipping through the new catalog and I was reading up on TMCC II and I was trying to figure out if this system includes the command base with the remote in one unit? Also does it use the same cables if you want to run a non TMCC engine. Kinda confusing
Not working for Lionel I’ll answer the questions as I see it in the catalog…
The Handheld unit and Command Base/ recharger are part of a package. They come together for the price quoted. Additional handhelds and chargers only are available as a unit.
As far as running non command engines, if you are using TPC then I do not believe anything else is required. If you are using a Powermaster, from what I understand a Legacy Powermaster Bridge (whatever that is) is needed.
You can check this all at http://www.coilcouplers.com/hirail/hirail00.shtml
Hope this helps.
