lionel transformers
Where can I find instructions for a lionel 1033 and RW transformers and how they connect to accessories. I have gates, spotlights and bell signals I would like to connect. I understand the track connection but not sure the best way to hook to these transformers. I will be using each of these transformers on separate tracks.
thanks
Peter Riddle’s books on wiring (Wiring Your Lionel Layout; I think the newer edition is called Wiring Your Toy Train Layout) talks all about wiring accessories, phasing more than one transformer, etc.
There’s also quite a bit of information at http://www.thortrains.net/manualx.htm and it will probably give you enough to get started. Riddle’s books are definitely worthwhile reading though.
Here’s a thread that may help, at least for the 1033
http://www.trains.com/community/forum/topic.asp?TOPIC_ID=28401
Olsen’s Toy Trains has Lionel’s PW service manual sections available:
http://pictures.olsenstoy.com/searchcd31.htm?itm=630 (The last page in this section is particularly helpful in determining connections.)
http://pictures.olsenstoy.com/searchcd31.htm?itm=640
http://pictures.olsenstoy.com/searchcd31.htm?itm=660
Dr. Riddle’s book recommends using the 1033’s A terminal for common, but that’s to run trains at 5-16V and have 16V fixed Voltage available. If you’re only using it to operate accessories, I’d recommend using the U terminal for common (same for the RW).
thanks
