Liquid Smoke - compatible for both Lionel and MTH?
My liquid smoke for my MTH PS1 Hudson Steamer has run out. Can the liquid smoke I have for my new Lionel engines be used with my MTH engine, or do I need to buy a manufacturer smoke?
I had been using the Lionel smoke in my MTH steamer & just the other day Tom, ( Spankybird ) said go ahead & put the JT megasmoke in it, and it has worked great ! Tons of smoke ! I think you only have to be careful with those Sueth smoke units. Hope this helps, thanks, John
They’re all basically the same, so any smoke fluid(for the most part) should work in any engines. The only types you should avoid are putting LGB or Seuthe fluid in a non-Seuthe unit, or vice-versa.
To answer your question, you’re fine putting Lionel fluid in your MTH engine.
Thanks guys!
