For the first half of the 20th century, a lot of “tinplate” live steam engines were produced. In England, this is still common (but not here). There are a goodly number of these tinplate beasts floating around the US. A lot of garden RR club members (like the Va, Md, and DC club, have a subset of O-gauge live steam aficionados who run their steam trains at meets; often on dual Gauge 1 and O gauge track (45 and 32 mm respectively).
I’m rather surprised this hasn’t yet caught on with the toy train crowd.
Types of fuel vary from alcohol and butane to real coal (using mini shovels). THe steam engines have safety valves, gauges, fireboxes; in short, everything a real steam train has. Also, it takes 5-10 minutes to get the steam up.
Distilled water is used to prevent scaling.
If you’ve ever operated live steam (seen, heard, smelt it); you’ll never go back.
I would LOVE to have an O Gauge live steam engine but there is a big gap between what $$ I make per year and what I’m guessing one of those would go for.
There are several models that are still out of my price range. There’s an O scale 0-4-0 for about $600 and a Mogul for about $750, the latter is British. I have the details at work.
If you run these indoors, you might want to open the windows and have the fire extinguisher available (truthfully, you should only operate these outdoors!)
There was a complete history of the Neff Model Manufacturing Company printed in Live Steam magazine sometime during the 1980s. I imagine that you could find what issue by visting their web site.
Roll Neff was a machinist of exceptional skill. He built his first O gauge locomotive in the late 1930s as a test platform to see what would work and what would not. Over the next 25 years, he custom built many O gauge locomotives - they were propane fired some were remote controlled. Usually this was not necessary - with a heavy train and a good track with well banked curves, additional control was not necessary. The locos would run until the fuel was exhausted - the boiler capacity and tender water supply being sufficient to keep the water level up so as to avoid running dry.
Neff’s locomotives ranged from a 4-4-0 with Stephenson gear to at least one 2-10-4 and several UP Big Boys. He was located in New York state and died either in the 1960s or 70s. I had a letter from him in the mid 1960s when I was trying to find an O gauger - at that time he had only one Big Boy in stock which was too big for my purposes.
Little Engines sold about 600 sets of O gauge castings over the years. Occasionally I see one of their locomotives but they are few and far between. Neff built between 50 and 100 locomotives. There were other custom builders during the 20s and 30s however most live steam locomotives were either Bassett-Lowke low pressure models or Bowman oscillators.
Here’s all of the skinny you’ll need on basic O gauge (and G) live steam. But WARNING: don’t look at the material b/c if U get your first live-steamer, they tell me it’s more addictive than drugs (there are a number of O scale live steam dealers, mostly in the UK, but some here)
Just thinking out loud here but wouldn’t it be cool if the boiler was heated by electricity, you know pull the juice from the track like a conventional O guage steam locomotive does? Combine that with some soft of command and control system and you would have the best of both worlds. Just make sure it’s water tight so it doesn’t fry it’s control boards.
Thank you! I have been looking everywhere fo a manufacter that sells o live steam. I really want one of these. I have only seen a small clip of one and already im addicted. I do need to know if i need to put the track on something like cement or if i am able to put the track on the grass. my concern with that is will it burn the grass? Also is there any controls for where you are sitting or standing to make it whistle and control the speed. I have nothing for this so…
Thanks…
