Loco wiring and motor replacement info
What is the best source of information about loco wiring and installing new motors. I have several old, but never used “can” motors and some locos with bad motors. I don’t want to get into them, without some info. I also have some that I would like to install a head light.
You might check out Proto Power West for repowering info.
Walter, go to http://www.ppw-aline.com/re-power.htm and look at the very bottom of the page. There is an excellent book on repowering locos at the bottom. This page lists everything you may need. May I recommend the drop-in motor mount cradle weights? They made my life much easier! [^]
