Locomotive Cabin and Caboose combined
The Locomotive Cabin and Caboose concepts must be combined into new control stations for locomotive consists anywhere in the train. This new Crew Control Cabin can have traction motors and power cells, but not a prime mover.
Separating the control station from the prime movers would minimize the repetitive vibrations the crew has to deal with on a daily basis. It would also allow for more collision safety features in the cabin.
Another possibility is that the railroads will make operations all remote control to reduce crew numbers.
Andrew
This sort of thing is already happening in yards with belt pack controlled locomotives.
http://www.ble.org/pr/news/headline.asp?id=6091
Distributed Power with several B-Units and a Separate Control Cabin is one way to make operating trains more effective and safer for the crew. Less slack in the train, more breaking power with Distributed Power Units.
A separate control cabin will allow any manifest train to be pulled apart to operate like a local for a time and then continue to the next yard or junction as the manifest freight.
Andrew
proposed by John Kneiling in the late 60’s and will probably never happen. I sure wouldn’t want to be in a box in front of all that weight and that vulnerable at grade crossings or in accidents.
Not sure what you are talking about.
Is this the same thing Amtrack is doing.
A Power unit on one end with full controls and a powerless control cab with full on the other end.
Depending on which way the train is going depends on which cab the engineer is sitting in and controling the train.
After hearing a recently built CN ES44DC, I hope the cabin they are in is soundproof enough. That knocking racket from the ES44DC is sure to get crews calling for a Control Cabin on a seperate platform.
The Fedral Railroad Administration issued a report about 8 years ago suggesting that crews would be better if they were not subjected to the noise, vibrations, and exhaust of the prime movers.
Andrew
