Locomotive Ditch Light Casing
Which vendor makes ditchlight casings for HO scale locomotives?
Gaskets??? more information is needed.
Do you mean the headlight housing that holds the lens? If so, Details West and Detail Associates are a couple of manufacturers that come to mind.
A suggestion that might be helpful for you, alloboard. For locating the above and for seeing what’s available in general as far as MRRing items are concerned is the Walthers catalog. It’s usually $15-$20 at your LHS but it’s a terrific resource and well-worth the investment - whether you buy anything directly from Walthers or not.
For the ditch lights I only use 2mm led’s and secure them with RTV silicone, I never use a “gasket” but I can’t imagine trying to put them in another appliance to secure them, maybe I’ve been doing it all wrong, but my method of the RTV seems to work for me! Jim
The gasket is probably too small to do as a seperate piece on HO, however a simulation might be made with an ultra fine brush to draw the line around the lens. This detail would be barely visible at 1 foot, let alone 2 feet away from the loco.
Yes I meant the headlight housing that holds the lens.
