locomotive lashups
How many locomotives do you typicaly run on your trains. And do u mix GE , EMD, ALCO ect together.
The interest of this is that I make sure that the models are geared the same . I normally do not run a Bachmann with an Athearn. I do run Life-like/life-like all the time.
I also purchase my locomtives in pairs just for this reason.
Mostlu I use a single, but I have been aquiring sets of two to run lately
I run whatever I need to. Most of my fleet is EMD. I have 1 Alco. This one normally runs by itself. I’ll run a Geep with my steam locomotives if they need help. Most of the time I don’t pu***he limits of my steam locomotives though.
Gordon
I buy sets of like engines. I find them easier to MU. I put the slow engine last to avoid destroying the couplers. The Steam, I run by themselves. If I need more pull with steam, I get the mallet out of the engine house.
On my old home layout 1-2 units.At the club I use 4-5 units in a locomotive CONSIST. I use ALCOS,EMDS and GEs in a locomotive CONSIST.
Hint its locomotive CONSIST not LASHUP.
There is nothing like a pair of K-4s pulling a passenger train around the layout. The Pennsy did not have to many ALCOs (steam) but favored Baldwins and power built in their own Juniata Shops. As for Diesels, I run a pair of Baldwins sharks. I would run more in the set, but I need to get some B-units.
Later…
for my GO Transit layout the top end on the commuters is 2 units and that is still pretty rare. On the CN freight trains though I run at most 3 and usually they are all of the same model make as that is usually the determining factor, not prototype builder.
Well I put two on the survey but the amount I actually am planning to use on the layout will vary from one to four, with two or three being typical. It will depend on the type of train.
I am in the room prep and planning stages of a section of a mainline, class one RR with a proto-freelanced rural branch of the class one. The main will have various trains passing through and, depending on what they are, will have one to four engines, as mentioned previously. A short transfer or caboose hop will have one engine, for example, where a full blown large through freight or coal drag from out west will have three or possibly even four locos. Mostly EMD units though a couple U-Boats mixed in as was typical for my prototype in the era I am modeling (late 1960’s).
The branch will typically have one or two GP 7/9’s on the short branchline trains plieing those rails, while the branch’s coal trains are planned to be powered by three SD7/9’s.
Hello Larry;
Hope you are well.
May I assume that Lash LaRue’s real first name was “Con” ?[;)][;)]
Regards
Mike[:D]
PA/B, E8A/B, F7A/B, the others didn’t look right with one loco, GP9, GP38, SD45, SD35, SD50, SD60M or SD70M, so started getting pairs, after trying to get a second SD35 and SD60M, got the P42 in a set. Want the last paint, so one more, but plan more locos per set, they never run the same, even run in together as a set. Usually don’t need the power, a dummy would be fine, but the single GP9 doesn’t have enough weight in N. Steam is too light also, small switchers too light. Does it count that my first trains were lash ups of 3-4 Pacific Electric cars? I may do a singe RSD1.
The old Timber rails only had one to two locos any way. The only time the were lashed up was when the other had broken down. I do however do a nice little SD75M lash up on my uncles basement Layout. He uses DCC and wow that stuff really helps get the loco’s looking great along with rather long almost realist train lengths.
It’d be a lot of fun putting a challenger behind a big boy and watching them haul a long frieght. But sadly none of thease are mine…oh well…I still have lots of fun with my 0-6-0.
The layout isn’t really big enough to warrant lash ups, but occasionally I doubled head a GP38-2 and GP40-2. Also the F3A sometimes run with its B unit. I don’t double head the steamers.
will be running single locomotives until i can finally purchase more and get my layout done.
I tend to run lashups as and when I need to - for example, I have a lengthy modern intermodal train (so far it has an Athearn 3-unit drawbar double stack, an Athearn Gunderson Maxi-III 5-unit double stack, a couple of the Walthers 5-unit spine cars and a 5-unit Athearn Impack, I’m looking to add another Maxi-III and maybe one of the Walthers drawbar-coupled 3-unit sets designed to take 53’ containers). This needs more than one loco, so it usually has an Athearn AC4400, a Bachmann Dash 8, and (hopefully) will soon have an Athearn Dash 9 as motive power. Interestingly enough, my Proto 1000 C-Liner A and B units have no trouble with the train!
It depends on what I am trying to run. If it is a peddler freight it gets one smaller unit, like a GP7, RS3 or maybe a switcher. If I am trying to run an ore drag I put up to 5 CC units on it, generally ALCO Centuries or GE U-boats. I mix up all of my locos except for the Baldwins, they run only with other Baldwins. But ALCOs, GEs, FMs, and EMDs all run in any combination I want.
Two units are enough to make the point. (Sorry.) They give the impression of multi-unit diesel operations, without taking up too much precious space. With cab units, I might use three to allow the use of a B-unit, and not have to turn the locomotives.
Of course, with steam, one unit is sufficient.
I’ll use one GP40-2 for locals, and the rest of the trains would be powered by two units.
I usually have just one on my trains, but sometimes I doublehead. For quite a while I used to have a really long CN frieght running on my layout pulled by 3 and then 4 units, but not anymore.
