Jim,
Please give us some more details. The Bachmann, is it a steamer with a tender or a diesel?
What brand is the other locomotive(s)?
For the standard Bachmann line, you may be able to find similar locomotives at a swap meet or train show.
Don’t take this negatively as I don’t want you to think I’m being discouraging-----------------it’s normally not worth it. Standard Bachmanns are too light, noisy, and are not smooth running units. The fact that the diesels need traction tires is a pretty good indicator. Their old steamers are attractive but again not smooth runners.
If you’re into diesels, consider purchasing either LifeLike’s Proto 2000 line, Athearn Blue Box, or yes, if you like Bachmann, you can get a Bachmann Spetrum diesel. The Spectrum Amtrak F40PH was a big hit with modelers about 10 years or so, ago.
If price is an issue check out Ebay as there are some very good deals to find. On the search box you can, for example, type: Proto 2000 SD7 or Athearn F7. A list on the particular unit you’re looking for pops open shows units that are up for bidding. Some have the “Buy it Now” option. Some deals are actually quite reasonable.
I won the bid for a Proto 2000 Special Edition SD45 for only $51. This same locomotive sells for $110 plus at most hobby shops! Athearn Blue Box locomotives often go for as little as $25, brand new!
Another option also is to check out some of the internet discount dealers. Some of the forum members here can provide you with good, recommendable dealers.
(make sure you don’t buy from Hobby Circle as their reputation for customer service is in the gutter)
Keep asking questions. Hope t
